11-08-2024, 02:13 PM | #1 |
Rep 4
PLEASE HELP ! 🥲
Firstly I want to apologise if I have written in the wrong section - I need help with my 116d .
Whenever I start my car after not driving it for a while ( typically morning or late afternoon) my car seems to not be going over 160-170 torque( looked in sport display) in any gear and I’m a bit concerned as this has only started happening in the past month or two , the car feels very sluggish and just abnormally slow ,BUT when I turn it off and then back on it’s goes back to going over 240 torque even if I do it right away in the morning - it’s a bit concerning as I’ve not seen anything similiar happening to anyone else . I’ve had it serviced and the issue still persists . Thank you and I apologise again if this is all posted in the wrong section |
11-08-2024, 02:38 PM | #2 |
Rep 20
Sounds like your swirl flaps. Have you run diagnostics and pulled any codes yet?
I believe you can delete these flaps from your manifold (or replace manifold) but first thing is diagnostics and see what codes you are getting if this is repeatable. |
robjank3.50 |
11-11-2024, 07:51 AM | #4 |
Rep 20
It certainly is an issue that needs resolved. You need to first run codes to see what comes up. You can delete flaps but I believe you will need to recode it afterwards or just replace entire manifold.
Or I could be completely wrong and it something else... Run diagnostics and go from there. Good luck and keep us updated! |
11-14-2024, 01:24 PM | #5 |
Rep 4
Hello , yes it is swirl flaps , my mechanic gave me two option either to get it deleted out of the car or to replace the manifold , he recommended to get it deleted so I no longer have to worry about it happening again in the future - if you were in my position what would you do?
