11-16-2024, 02:30 AM | #1 |
Rep 1
Hello all,
I have recently had my car (F20) tuned by a professional (Stage 1 remapping) and I am little concerned about the following: a) what will happen if BMW service center updates the software? will it erase the remapping? b) any way to back it up? c) is using Bimmercode to code basic settings (i.e. auto start-stop) will overwrite the remapping? Thanks ![]() |
11-16-2024, 02:35 PM | #3 |
![]() ![]() 123
Rep 245
Coding modules using Bimmercode or any other application does not impact the ECU map.
If the car is reflashed by the dealer you will need to have the tuner reflash the ECU if you did not use BM3 / MHD to unlock it or flash it yourself.
16 M235 Cabrio - BM3 Stage 2, XHP, ER CP, Wagner DP & Comp IC, MPE, Torqbyte CM5 Water-Meth
18 340i F30 mostly stock |
nostromo_0.00 |
